vivo continues to expand its product lineup. As part of these efforts, the Chinese brand has introduced the Y37c model, which draws attention with its technical specifications. So, what exactly does the brand’s new model offer? Here are the details!
vivo Y37c Specifications and Price
The vivo Y37c features a 6.56-inch LCD display with HD+ resolution and a 90 Hz refresh rate. Additionally, it offers a waterdrop notch design and a peak brightness of 570 nits.
The device is powered by the Unisoc T7225 processor. It comes with 6 GB of LPDDR4x RAM and 128 GB of eMMC 5.1 internal storage. Users also have the option to expand the memory thanks to virtual RAM support.
On the front, there is a 5 MP selfie camera, while the rear houses a 13 MP main camera. The smartphone is equipped with a 5,500 mAh battery that supports 15W charging speeds.
Priced starting at around 275 USD, the device’s full technical specifications are as follows:
Feature | Details |
Display | 6.56-inch LCD, HD+ resolution, 90Hz refresh rate, 570 nits brightness, Waterdrop notch |
Eye Protection | Blue light reduction support |
Durability | IP64 certified (dust and water resistant) |
Front Camera | 5 MP |
Rear Camera | 13 MP + LED flash |
Operating System | OriginOS 4 (based on Android 14) |
Processor | Unisoc T7225 |
RAM | 6 GB LPDDR4x (+ Virtual RAM support) |
Storage | 128 GB eMMC 5.1 |
Battery | 5,500 mAh, 15W fast charging |
Security | Side-mounted fingerprint scanner |
Connectivity | Dual SIM 4G, Wi-Fi 5, Bluetooth 5.2, USB-C, 3.5mm headphone jack |
Dimensions | 167.30 x 76.95 x 8.19 mm |
Weight | 199 grams |
Color Options | Dark Green, Titanium |
Price | 1,199 Yuan (~275 USD) |
Availability | Currently available only in China |
