Smartphones
    6,000 mAh battery and 120 Hz display: OPPO A5 5G introduced!
    After A5 Pro 5G and A5x 5G, OPPO has now launched the OPPO A5 5G model. Here are the OPPO A5 5G features and price!
    Priced at $180, this new model is positioned between the A5x and A5 Pro in terms of price. The device stands out with its robust build and performance suitable for everyday use.
    The OPPO A5 5G comes with an IP65 rating for protection against dust and water splashes, and it also meets MIL-STD-810H military-grade durability standards. The phone is SGS Gold durability certified and features reinforced ports, waterproof seals, and dual-tempered glass that is 160% stronger than standard glass. It is also equipped with Gorilla Glass 7i and a tough alloy frame, offering resistance against impacts, scratches, and harsh environments.
    The smartphone features a 6.67-inch LCD panel with a resolution of 1604 x 720 pixels, a 120Hz refresh rate, 264 ppi pixel density, and 1,000 nits peak brightness in HBM mode. For security, it includes a side-mounted fingerprint sensor. On the software side, it runs ColorOS 15 based on Android 15.
    Powered by the MediaTek Dimensity 6300 chipset, the OPPO A5 5G offers 6 GB or 8 GB LPDDR4X RAM options and 128 GB UFS 2.2 storage, expandable via microSD card. The phone is backed by a 6,000 mAh battery with support for 45W fast charging.
    In the camera department, the rear setup includes a 50 MP main sensor paired with a 2 MP monochrome sensor, while the front features an 8 MP selfie camera. Other notable features include 5G support, Wi-Fi 5, Bluetooth 5.4, and a USB-C port.
    FeatureDetails
    Display6.67-inch LCD, 1604 x 720 pixels, 120Hz
    ProcessorMediaTek Dimensity 6300
    RAM6 GB or 8 GB LPDDR4X
    Storage128 GB UFS 2.2 + microSD card support
    Rear Cameras50 MP (main) + 2 MP (monochrome)
    Front Camera8 MP
    Operating SystemColorOS 15 (based on Android 15)
    Battery6,000 mAh, 45W fast charging
    Connectivity5G, Wi-Fi 5, Bluetooth 5.4, USB-C
    DurabilityIP65, MIL-STD-810H, Gorilla Glass 7i
    Dimensions165.7 x 76.2 x 7.9 mm
    Weight194 grams
    Fingerprint SensorSide-mounted
    Color OptionsAurora Green, Mist White
    Price (India)₹15,499 (6GB+128GB), ₹16,999 (8GB+128GB)
