Computers
    AOC Q27G4SMN launches with Mini LED, 1440p, and 300 Hz refresh
    The AOC Q27G4SMN is a 27-inch Mini LED gaming monitor with a 300 Hz refresh rate, 1440p resolution, and 1,152 dimming zones for deep contrast.
    AOC-Q27G4SMN-1
    AOC has pulled the curtain back on the AOC Q27G4SMN, a new gaming monitor built for speed and contrast. It features a 27-inch Fast VA panel with Mini LED backlighting and a 300 Hz refresh rate making it one of the most aggressive spec combos in its class.
    With 1,152 dimming zones and strong HDR performance, this monitor aims squarely at high-end competitive gamers.
    AOC-Q27G4SMN-2
    The Mini LED backlight gives the AOC Q27G4SMN an edge in brightness and black levels. HDR peak brightness reaches 1,200 nits, while SDR tops out at 450 nits. That puts it in the same league as more expensive HDR monitors on the market.
    Thanks to the VA panel, you get naturally deeper blacks, but viewing angles may still suffer compared to IPS screens.
    Agon U27G4XM brings Mini LED, 4K, and 160 Hz under $550
    While it’s clearly built for play, AOC says the Q27G4SMN delivers on color accuracy too. It covers 97% of the DCI-P3 color space and boasts a Delta E under 2. That makes it suitable for content creators who need decent color precision but still want high refresh rates for gaming.
    The 2560 x 1440 resolution hits a sweet spot between 1080p speed and 4K clarity ideal for gaming without overloading your GPU.
    Ergonomics and ports aren’t an afterthought here. The Q27G4SMN features:
    • Tilt, swivel, and pivot adjustments
    • VESA mounting compatibility
    • 2x HDMI 2.1 ports
    • 1x DisplayPort 1.4
    • 1x 3.5 mm audio out
    The design checks all the right boxes for flexible setups, whether you’re mounting it or adjusting for desk space.
    Even with the Mini LED tech and strong brightness numbers, the Fast VA panel may not please everyone. Poor viewing angles remain a sticking point for users coming from IPS panels, and blooming could be a concern with such a high number of dimming zones though real-world testing will confirm how it handles edge glow and contrast transitions.
    For those chasing speed, contrast, and versatility in a single display, the AOC Q27G4SMN brings a strong feature set at what’s likely to be a competitive price. Whether you’re pushing frame rates in esports or editing content during the day, this monitor makes a serious case for itself, if you’re okay with the VA quirks.
