Aoostar Nex395 arrives with Strix Halo power and 128 GB RAM
The Aoostar Nex395 is no longer a teaser, it’s a real, shipping machine, and it’s armed to shred expectations.
Aoostar Nex395 officially launches in China
After months of buildup, Aoostar has pulled the cover off the Nex395. The final design differs from what was teased earlier this year, but what’s under the hood is even more ambitious. Now available in China, the compact PC pairs AMD’s high-end Strix Halo APU with an absurd 128 GB of LPDDR5X RAM.
That’s not just quantity, it’s quality too. The memory runs at 8,533 MT/s, which is fast enough to handle local AI workloads, heavy multitasking, or anything short of a nuclear reactor simulation.
ViWoods AiPaper Reader C shakes up Android eReaders with color and SIM
Aoostar Nex395 runs AMD’s most powerful integrated GPU
Inside the Nex395 is the AMD Ryzen AI Max+ 395 chip, which features the Radeon 8060S iGPU. This isn’t your average integrated graphics. It punches in the same performance class as NVIDIA’s RTX 4070 Laptop GPU in many scenarios.
That gives the Nex395 serious GPU muscle, whether you’re working in creative apps, running AI inference, or just gaming on the side. Add in three M.2 PCIe 4.0 SSD slots and a 2 TB default config, and you’ve got performance with zero fluff.
Custom cooling keeps the Aoostar Nex395 stable
Even small machines can run hot, but this one doesn’t. Aoostar’s Glacier VC cooling solution claims to keep things cool under pressure. That means fewer thermal slowdowns, even when you push the 140 W performance mode.
Meanwhile, the compact form factor makes it easy to open and upgrade. And no, you won’t be short on ports.
Here’s what’s built in:
- 2x USB4
- 2x 2.5G Ethernet
- 3x USB 3.2 Gen 2 Type-A
- 1x USB 2.0
- 1x HDMI
- 1x DisplayPort
- 1x 3.5 mm audio
Aoostar Nex395 keeps it small but stacked
At just a fraction of a desktop’s footprint, the Aoostar Nex395 doesn’t compromise on firepower. It’s built to handle AI, creation, and high-end workflows all without taking over your desk. Aoostar priced the 2 TB version at CNY 14,999 (roughly $2,121), and while global availability is still unknown, its ambition is crystal clear.
Strix Halo meets the edge of performance
The Aoostar Nex395 doesn’t try to be sleek or quiet, it shows up armed and unbothered. Mini in size, maximum in everything else.
