    China Initiates Assembly of Its Cutting-Edge Artificial Sun Reactor
    China has started the assembly phase of its BEST nuclear fusion reactor, aiming to achieve a self-sustaining burning plasma and prove net energy gain by 2027.
    China has achieved a significant milestone in its ambitious quest to master nuclear fusion by initiating the critical assembly phase of the Burning Plasma Experimental Superconducting Tokamak (BEST) reactor in Hefei. Launched in 2023, this massive undertaking represents a major leap forward in the nation’s efforts to harness the power of an artificial sun as a clean, sustainable future energy source. Engineers have transitioned from the initial building construction phase to the precise physical installation of core reactor components. With key infrastructure now in place, the facility is being prepared to house the complex systems required for high-temperature plasma experiments.
    • The BEST project aims to achieve a sustainable burning plasma state using deuterium and tritium isotopes.
    • Engineers have begun the installation of critical systems including the vacuum vessel and toroidal field magnets.
    • The reactor is designed to produce between 20 and 200 megawatts of fusion power to demonstrate a net energy gain.
    • Completion of the experimental reactor is scheduled to occur by the end of 2027.
    The Project Aims to Create Burning Plasma
    The BEST reactor is not merely a standard experimental device; it is engineered to facilitate a genuine burning plasma environment. By utilizing isotopes of deuterium and tritium, the project seeks to achieve a self-sustaining fusion reaction, a feat that has long remained the
