    DJI Osmo 360 II Leaks Reveal Larger Battery and NFC
    DJI Osmo 360 II leaks reveal a larger 2,150 mAh battery and NFC connectivity, pointing to a major hardware upgrade for the upcoming 360-degree action camera.
    Tech giant DJI is preparing to strengthen its position in the 360-degree camera market as new leaks reveal the upcoming DJI Osmo 360 II. Following the success of its predecessor, the company is actively developing this next-generation device, currently identified by the model number OQ002. Recent filings with the Federal Communications Commission (FCC) and emerging engineering prototype images confirm that the successor maintains its durable, compact design while introducing significant internal hardware upgrades. These improvements, which target battery efficiency and connectivity, position the device as a formidable competitor against other leading action camera manufacturers currently vying for market dominance.
    • The device features an upgraded battery capacity of 2,150 mAh to support longer recording sessions.
    • New NFC integration facilitates rapid pairing and high-speed data transfer between the camera and smartphones.
    • The camera retains the robust, dual-lens design of the original model while improving internal power management.
    Design Standards are Maintained While Hardware Components Improve
    Leaked production data suggests that the DJI Osmo 360 II will retain the aesthetic and structural identity of its predecessor. The camera continues to utilize a rugged, square-shaped chassis designed to withstand harsh outdoor environments, paired with its signature dual-lens array. Despite the familiar physical appearance, the internal architecture has undergone a complete overhaul to meet the increasing performance demands of modern content creators.
    The transition from a 1,950 mAh battery to a 2,150 mAh unit ensures significantly longer operational times during demanding 360-degree video captures.
    This capacity boost is essential, as high-resolution panoramic recording places a heavy load on the device’s sensors and processors. By extending battery life, DJI is addressing a primary pain point for professionals who previously relied on frequent charging breaks or external power banks.
    NFC Technology Enhances Connection Capabilities
    One of the most notable hardware additions to the DJI Osmo 360 II is the integration of Near Field Communication (NFC) technology. While many high-end panoramic cameras currently lack this feature, its inclusion in this model significantly simplifies the user experience.
    By simply tapping the camera against a smartphone, users can initiate a seamless connection. This integration is not just for convenience; it streamlines the wireless transfer of large, high-resolution video files and high-bitrate photographs, making the workflow much more efficient for creators on the go.
    The Legacy of the Original Osmo 360 Continues
    To understand the anticipation surrounding the new model, one must look at the performance benchmarks set by the original device launched in July 2025. That camera introduced a 1-inch sensor capable of capturing 8K resolution at 50fps, along with 120-megapixel still images. Reports indicate that the Osmo 360 II may push these boundaries even further, potentially reaching 60fps at 8K resolution.
    Engineering refinements suggest that the new device will serve as a definitive tool for both professional videographers and amateur adventure enthusiasts.
    Official Launch Timelines Remain Unconfirmed
    While DJI has not issued an official announcement regarding a release date, the presence of FCC certification and field test footage indicates that the product has entered the final stages of development. Historical data shows that similar certification milestones typically precede a commercial release by only a few months. As the company finalizes software optimizations, an official unveiling is expected in the near future.
    What are your thoughts on the potential features of the upcoming DJI Osmo 360 II, and which specific upgrade are you most excited to see in action? Share your opinions in the comments section below.
