    Honor X8e 4G Debuts with 108MP Camera and Massive Battery
    The Honor X8e 4G has been launched, featuring a 108MP camera, a massive 7,700mAh battery, and extreme durability ratings for the entry-level market.
    Honor has officially expanded its entry-level smartphone lineup with the launch of the Honor X8e 4G, a device that stands out for its robust build quality and impressive internal specifications. Spotted on the company’s official Azerbaijani website, this new model shares several design and performance characteristics with the previously released Honor X7e Plus 4G. The most notable feature of the Honor X8e 4G is its 108MP primary camera sensor, a high-resolution component rarely seen in this budget-conscious market segment. Aimed at users who prioritize durability and endurance, the smartphone combines modern aesthetics with a rugged engineering approach.
    • The Honor X8e 4G features a 108MP main camera sensor alongside a 7,700mAh battery capacity.
    • The device incorporates the Snapdragon 685 chipset and a 6.87-inch LCD panel with a 120Hz refresh rate.
    • It carries IP68, IP69, and IP69K certifications to ensure high levels of water and dust resistance.
    • The handset is built to withstand extreme temperatures ranging from -30°C to +50°C.
    Hardware and Display Specifications Perform Well
    Under the hood, the device is powered by the octa-core Snapdragon 685 chipset, utilizing a 6nm manufacturing process to balance performance and power efficiency. The hardware setup includes Cortex-A73 and A53 cores, paired with the Adreno 610 GPU to handle everyday tasks. While the device is limited to 4G connectivity, it supports dual nano-SIM slots, Wi-Fi 5, and NFC technology. Out of the box, the phone runs on the MagicOS 10 interface, which is based on Android 16, ensuring users have access to the latest software optimizations.
    The visual experience is centered on a 6.87-inch LCD screen. Although the resolution is set at 720 x 1,592 pixels, the inclusion of a 120Hz refresh rate ensures fluid animations and scrolling. Furthermore, the display reaches a peak brightness of 1,020 nits, which significantly improves outdoor visibility under direct sunlight. A small punch-hole cutout at the top houses a 5MP selfie camera, maintaining a clean and modern aesthetic for the front panel.
    Durability Standards Define the Design
    One of the most significant selling points of the Honor X8e 4G is its massive 7,700mAh battery, which supports 45W Honor SuperCharge technology to minimize downtime. Beyond battery life, the device is engineered for extreme physical environments. It holds IP68, IP69, and IP69K ratings, guaranteeing protection against high-pressure water jets and high-temperature immersion.
    Testing confirms that the device remains functional in extreme temperatures, operating flawlessly between -30°C and +50°C. The chassis is resistant to salt and high humidity, while the screen is optimized to detect touch inputs even when wet. With an SGS-certified 5-star drop resistance rating, the phone is designed to survive falls from 2.5 meters. Available in Sunrise Orange, Desert Gold, and Velvet Black, the phone comes with 6GB of RAM and 256GB of internal storage, retailing at 820 AZN.
    Given the remarkable focus on extreme durability and the inclusion of such a high-capacity battery, we are curious to hear your take on this device. Would you prioritize these rugged features over a higher-resolution display? Share your thoughts in the comments section below.
