    Jmgo N3 4K triple laser projector launches in US with Dolby Vision and 300-inch display support
    Jmgo N3 4K projector launches in US with Dolby Vision, Google TV, and 300-inch display support now $1,099 for a limited time.
    Jmgo-N3-4K-1
    Jmgo has officially brought its N3 4K triple laser smart projector to the US market. Already on sale in Europe, this home theater-focused model combines native 4K resolution, Dolby Vision, and an ultra-wide projection size all at a competitive price.
    Jmgo-N3-4K-2
    The N3 uses a native 4K resolution (3,840 x 2,160) and covers 110% of the BT.2020 color space, promising crisp images and vivid color accuracy. The projector supports screen sizes between 40 and 300 inches, making it suitable for everything from apartment walls to full-sized home theater setups.
    To simplify setup, the N3 includes automatic focus, keystone correction, and screen alignment. It also features an adjustable stand that lets you tilt the device by up to 160°, providing flexible placement options for a variety of rooms and surfaces.
    Xiaomi Sound Pocket ultra-compact speaker launches in Europe with 10-hour battery and waterproof build
    At its core, the projector runs on MALC 3.0 triple laser tech, generating up to 1,800 ISO lumens of brightness. While not designed for bright sunlight, it’s more than capable in typical living room lighting.
    It supports both Dolby Vision and HDR10, backed by a 1,600:1 FOFO contrast ratio and a 1,000,000:1 dynamic contrast ratio, helping dark scenes look deep without sacrificing clarity in highlights.
    Here’s a breakdown of key specs:
    • 4K UHD resolution (3,840 x 2,160)
    • Triple laser light source (MALC 3.0)
    • 1,800 ISO lumens
    • Dolby Vision and HDR10 support
    • Image size: 40–300 inches
    • 1.0–1.3:1 throw ratio
    • 160° angle-adjustable stand
    • Google TV with built-in Netflix, Prime Video, Disney+
    • Dual 10W speakers, Wi-Fi 6, Bluetooth 5.2
    • HDMI (eARC), USB, 3.5 mm audio
    Running on Google TV, the Jmgo N3 includes access to popular streaming apps and voice control via Google Assistant. With Google Cast built in, you can stream directly from your Android or Chrome browser without additional hardware.
    The projector also features dual 10W speakers, eliminating the need for an external soundbar for casual viewing. Its compact frame measuring just 245 x 195 x 223 mm comes in a modern gray finish, blending neatly into home environments.
    The N3 is now available in the US at $1,099, currently $300 off its $1,399 MSRP. You can find it on Jmgo’s official store and at Best Buy. However, the company hasn’t said how long the discounted price will last.
