    Realme C100x Launches in India With 8,000 mAh Battery
    Realme C100x launches in India featuring an 8,000 mAh battery, 120Hz display, and military-grade durability starting at 14,499 INR.
    Realme has officially brought its latest durable smartphone, the Realme C100x, to the Indian market today, nearly two months after its initial global unveiling. Positioned as a rugged device designed for longevity, the handset aims to capture attention with its massive power capacity and military-grade build quality. Available through the official Realme India website and Flipkart, the device is tailored for users who prioritize battery life and physical resilience in their mobile hardware. By integrating high-capacity components and specialized protective features, the company intends to establish a strong presence in the competitive entry-level segment.
    • The Realme C100x features an 8,000 mAh battery with 45W fast charging support.
    • The device incorporates MIL-STD-810H military-grade certification and IP64 protection.
    • The smartphone retails at 14,499 INR for the 4GB RAM and 64GB storage configuration.
    Battery Capacity Defines the User Experience
    The standout feature of the Realme C100x is undoubtedly its robust 8,000 mAh battery, which significantly outperforms the 7,500 mAh version available in other global markets. This substantial power reserve is complemented by 45W fast charging, ensuring that users can minimize downtime despite the high capacity.
    The device offers an unprecedented battery life that caters to heavy users and outdoor enthusiasts alike.
    Display Technology Ensures Visual Clarity
    Equipped with a 6.81-inch HD+ LCD screen, the phone provides a smooth visual experience thanks to its 120Hz refresh rate. The panel reaches a peak brightness of 900 nits, making it readable even in challenging lighting conditions. To ensure durability, the Indian variant of the display is fortified with specialized Panda@MN228 glass.
    Hardware Specifications Power the Device
    Under the hood, the smartphone is powered by the Unisoc T7250 processor, paired with 4GB of LPDDR4X RAM. It comes with 64GB of internal storage and runs on the Realme UI interface, which is based on Android 16. While not a performance-heavy flagship, the configuration is sufficient for standard daily tasks and multitasking within its category.
    Design Standards Protect the Hardware
    Beyond internal power, the Realme C100x is built to withstand harsh environments. It carries an IP64 rating for dust and water resistance, along with MIL-STD-810H military-grade certification for drop and shock resistance. Furthermore, the touch interface is optimized to function even when the user is wearing gloves or if the screen surface is wet or oily.
    Advanced durability standards make this smartphone a reliable tool for demanding field conditions.
    Connectivity and Pricing Remain Competitive
    Additional features include a side-mounted fingerprint scanner for enhanced security and a 3.5mm headphone jack for audio convenience. The device also supports 6W reverse wired charging, allowing users to power up other small accessories using the phone’s massive battery. The model is currently offered in Deepblue Tides and Golden Cost color options. Priced at 14,499 INR, the phone represents a strategic move by Realme to offer high-end endurance at an accessible price point.
    Given the impressive 8,000 mAh battery capacity and the rugged build of the new Realme C100x, do you believe this device offers enough value for your daily needs, or is performance your top priority? Share your thoughts in the comments section below.
