Smartphones
    Release date given for vivo Y300 GT with 7620 mAh battery!
    The vivo Y300 GT will be available to users on May 9, and pre-orders have already begun. Here are the details.
    vivo continues to expand its product portfolio and is now preparing to launch a new model in its Y300 series, which already includes models like the Y300, Y300+, Y300i, Y300t, and Y300 Pro+. The Chinese brand is counting down to the introduction of the vivo Y300 GT, and recent developments have revealed both its key specifications and launch date.
    The vivo Y300 GT is set to debut on May 9, with pre-orders reportedly already underway. The smartphone is expected to be powered by the MediaTek Dimensity 8400 chipset and will house a massive 7,620 mAh battery supporting 90W fast charging.
    Although not officially confirmed, speculation suggests the Y300 GT could be a rebranded version of the Z10 Turbo, which was just unveiled. If these claims prove true, both devices may share identical core specs despite differences in design and branding.
    In that case, the Y300 GT will likely feature a 6.78-inch flat OLED panel offering 1.5K resolution and a 144Hz refresh rate. It is also expected to be available with up to 16 GB of LPDDR5x RAM and 512 GB of UFS 4.1 storage.
    To give a clearer idea, here are the full specifications of the iQOO Z10 Turbo:
    FeatureDetails
    NetworkGSM / HSPA / LTE / 5G
    AnnouncementApril 28, 2025
    Release DateApril 28, 2025
    Dimensions163.7 x 75.9 x 8.1 mm
    Weight212 g
    BuildGlass front, plastic back and frame
    SIMDual Nano-SIM
    IP RatingIP65 – Dust resistant, water resistant under low pressure
    Display TypeAMOLED, 1B colors, 144Hz, HDR, 2000 nits (HBM), 4400 nits (peak)
    Display Size6.78 inches (~89.3% screen-to-body ratio)
    Resolution1260 x 2800 pixels (~453 ppi)
    Extra Display FeaturesAlways-on display
    OSAndroid 15, OriginOS 5
    ChipsetMediaTek Dimensity 8400 (4 nm)
    CPU1×3.25 GHz + 3×3.0 GHz + 4×2.1 GHz (Cortex-A725)
    GPUG720 MC7
    Memory Variants256GB 12GB RAM, 256GB 16GB RAM, 512GB 12GB RAM, 512GB 16GB RAM (UFS 4.1)
    Card SlotNone
    Rear Cameras50 MP (wide, OIS) + 2 MP (depth)
    Camera FeaturesColor sensor, LED flash, HDR, panorama
    Rear Video4K, 1080p, gyro-EIS, OIS
    Front Camera16 MP (wide)
    Front Video1080p@30fps, gyro-EIS
    AudioStereo speakers, no 3.5mm jack
    Wi-FiWi-Fi 6, dual-band
    Bluetooth6.0, A2DP, LE, aptX HD
    PositioningGPS, BDS, GALILEO, QZSS, NavIC, GLONASS
    NFCYes
    IR BlasterYes
    RadioNo
    USBUSB Type-C 2.0, OTG
    SensorsUnder-display fingerprint, accelerometer, gyroscope, proximity, compass
    Battery7,620 mAh, Silicon-Carbon Li-Ion
    Charging90W wired (100% in 55 mins), reverse wired charging
    ColorsWhite, Black, Orange, Gold
    Model NumberV2452A
    PriceApprox. €220
