    Roborock Qrevo Edge 3 Pro Launches in Turkey
    Roborock Qrevo Edge 3 Pro debuts in Turkey, offering 36,000 Pa suction and advanced AI features specifically designed for pet-friendly households.
    Roborock, a global leader in smart home cleaning technology, has officially launched its latest flagship robot vacuum, the Qrevo Edge 3 Pro, in the Turkish market. Designed specifically to assist pet owners in managing the daily challenges of household maintenance, this advanced model addresses common issues such as shedding fur, scattered toys, and unpredictable pet movement. With a staggering 36,000 Pa suction power, sophisticated artificial intelligence for object recognition, and specialized software tailored for households with animals, the device sets a new standard for automated home care in Turkey.
    • The device utilizes 36,000 Pa suction power to remove pet hair and debris from carpets and floor crevices.
    • An integrated automatic detection system identifies cats and dogs to prevent collisions and avoid startling them during operation.
    • The station cleans mop pads using water heated to 100°C to eliminate bacteria and stubborn stains.
    • Roborock enforces strict privacy standards by keeping camera features disabled by default and employing end-to-end encryption for all video streams.
    Artificial Intelligence Prevents Unwanted Collisions
    A core feature of the Qrevo Edge 3 Pro is its Automatic Pet Detection system. When the vacuum senses the proximity of a cat or dog, it immediately pauses the rotation of its main brush and adjusts its path. This gentle maneuvering ensures that pets remain calm and undisturbed by the cleaning process, significantly reducing the risk of accidental contact.
    Furthermore, the Reactive AI obstacle avoidance architecture has been upgraded to recognize over 300 types of objects. By distinguishing between cables, shoes, pet bowls, and toys, the robot navigates complex living environments with ease. This intelligence minimizes the need for manual intervention and prevents the vacuum from becoming trapped by common household clutter.
    Remote Monitoring Features Provide Enhanced Security
    Beyond its vacuuming capabilities, the Qrevo Edge 3 Pro functions as a mobile pet monitoring hub. Through the Roborock mobile application, users can activate the Instant Pet Photo function, which captures images of pets encountered during cleaning cycles. Additionally, the device allows owners to locate their pets on a digital map and even navigate the vacuum manually to check on their home remotely via video calls.
    Roborock has placed a high priority on data privacy regarding these surveillance functions. The camera and live-streaming features are strictly disabled by default, requiring explicit user authorization to activate. All captured media is stored with encryption on the local hardware, while live video feeds are protected by advanced end-to-end security protocols.
    High Performance Cleaning Systems Simplify Maintenance
    The vacuum’s hardware is engineered for maximum durability and efficiency. Its DuoDivide™ main brush is specifically designed to minimize hair tangling, while the FlexiArm™ side brush reaches deep into difficult corners. The combination of these tools ensures that the robot maintains peak performance with less frequent maintenance requirements.
    Station Functions Ensure Complete Hygiene
    The all-in-one docking station provides a comprehensive self-cleaning cycle for the robot. After each session, the station washes the dual rotating mop pads with 100°C water to dissolve grease and sanitize the fabric. The station then performs an automatic detergent dose and dries the pads with hot air to prevent mold and bacterial growth. This automated process ensures that the home environment remains consistently hygienic without requiring human input.
    If you are a pet owner, how much time do you spend cleaning up after your furry friends every week? Share your experiences with automated cleaning solutions in the comments below.
