Vivo T5 5G Launches With Curved Display and Massive Battery
Vivo has officially unveiled the Vivo T5 5G, a mid-range smartphone set to launch in the Indian market on September 9, 2026. Priced starting at 34,999 Rupees, the device distinguishes itself with a premium 6.83-inch curved AMOLED display and a substantial 7,050mAh battery. The smartphone integrates the powerful MediaTek Dimensity 7500 Turbo chipset, positioning it as a competitive option for users seeking high performance in the mid-range segment. With advanced cooling technologies, durable build quality featuring IP68 and IP69 ratings, and long-term software support, the Vivo T5 5G aims to capture a significant share of the global smartphone market.
- The Vivo T5 5G features a 6.83-inch AMOLED screen with a 144Hz refresh rate and a peak brightness of 3,000 nits.
- The device houses a 7,050mAh battery that supports 44W fast charging and maintains longevity over 1,600 charge cycles.
- It operates on a MediaTek Dimensity 7500 Turbo chipset paired with up to 12GB of physical RAM.
- The handset includes a 50-megapixel primary camera equipped with a Sony IMX882 sensor and optical image stabilization.
The Display and Performance Hardware Deliver Power
The core of the Vivo T5 5G experience is its high-resolution 2800 x 1260 AMOLED panel. By combining a 144Hz refresh rate with 3,000 nits of peak brightness, the device ensures fluid navigation and excellent visibility even in harsh lighting conditions.
Behind this display sits the 4nm MediaTek Dimensity 7500 Turbo processor. To maintain optimal performance during gaming or intensive multitasking, Vivo has integrated a large 3,800mm² vapor chamber cooling system that effectively manages heat dissipation.
Storage and memory configurations cater to various user needs, ranging from a base model of 6GB RAM and 128GB storage to a high-end variant with 12GB RAM and 256GB of internal space. Users can further expand their multitasking capabilities through virtual RAM support, which adds an extra 12GB of memory. While the device lacks a microSD card slot, it keeps up with modern connectivity standards by including support for Wi-Fi 6 and Bluetooth 5.4.
Battery and Camera Systems Impress Users
Perhaps the most significant feature of this smartphone is its 7,050mAh battery. Vivo claims this capacity provides up to 85 hours of music playback or 34.7 hours of continuous video streaming.
Complementing the battery is 44W fast charging, ensuring that users can quickly replenish power while maintaining long-term battery health for up to 1,600 cycles.
Photography enthusiasts are supported by a versatile camera array. The primary 50-megapixel sensor uses the high-quality Sony IMX882 lens, which benefits from optical image stabilization (OIS) for sharper photos and smoother videos. The rear setup is completed by an 8-megapixel ultra-wide lens, while the front features a 32-megapixel selfie camera. Both the front and rear systems are capable of recording 4K video at 30fps.
Software and Durability Standards Meet Requirements
Out of the box, the device runs OriginOS 6 based on Android 16. Vivo has committed to a robust software roadmap, promising three generations of Android OS updates and five years of security patches. The build is further reinforced by IP68 and IP69 ratings, offering high levels of resistance against water and dust ingress. Additional quality-of-life features, such as stereo speakers and an integrated optical in-display fingerprint sensor, round out the technical specifications.
Given the competitive price point and the inclusion of a 7,050mAh battery, do you think the Vivo T5 5G offers the best value in its class, or would you prefer a device with different priorities? Share your thoughts in the comments section below.
