Apple, which introduced the iPhone 15 series last year, will come up with the iPhone 16 series this year. A lot of information about the new models has leaked so far. So what differences will the iPhone 16 Pro Max have compared to the iPhone 15 Pro Max?
Differences between iPhone 16 Pro Max and iPhone 15 Pro Max (Claim)
Looking at the list shared by the account AppleLeaker, we see that the iPhone 16 Pro Max will come with a 48 Megapixel ultra-wide-angle camera. This resolution was 12 Megapixels on the iPhone 15 Pro Max. In this context, there is a significant upgrade.
However, the new device will have a larger screen at 6.9 inches compared to its predecessor. There will also be smaller bezels thanks to BRS technology, a Qualcomm X75 modem for better cellular connectivity, and a new rose color. See the full list below.
The iPhone 16 Pro Max will have the following upgrades compared to its predecessor;
- 48 Megapixel ultra-wide camera
- Larger 1/1.14″ main camera
- New 8-element hybrid lens
- 4K Spatial video
- A18 Pro chip (N3E node), possibly with 2 additional efficiency cores
- Significantly improved neural network for on-device AI features
- Upgraded titanium chassis with a more polished surface
- Larger 6.9″ screen
- Better OLED display with increased brightness
- Smaller frames using BRS technology
- New capacitive capture button
- Metal case battery for improved thermals
- Stacked battery design for increased energy density and potentially faster charging
- Graphene thermal system
- Improved microphones with better signal-to-noise ratio
- Wi-Fi 7 connection
- Qualcomm X75 modem for better cellular connectivity
- New rose color
So what do you think about this issue? What are your expectations from the iPhone 16 Pro Max model? You can share your opinions with us in the Comments section below.
