Huawei Unveils Innovative Wind Chaser Piezoelectric Cooling Stand
Huawei officially introduced its groundbreaking Huawei Wind Chaser, an ultra-thin cooling stand designed for smartphones, during the recent Double Eleven Renewal Season & All-Scenario New Product Launch Conference. The device was unveiled by He Gang, Huawei Executive Director and Terminal BG CEO, highlighting the company’s focus on integrating active cooling into a portable form factor. By utilizing advanced piezoelectric technology, the Huawei Wind Chaser serves as both a high-efficiency cooling solution and a functional device stand, marking a significant departure from traditional mechanical fan designs that often rely on bulky motors and rotating blades.
- The cooling device employs a 0.65 mm thick piezoelectric fan that generates airflow through 29,000 vibrations per second.
- An aluminum alloy body and integrated hidden hinge enable the stand to unfold up to 110 degrees for flexible viewing angles.
- The accessory utilizes a gecko-inspired micro-suction system to provide up to 40 newtons of adhesion without requiring magnets or adhesives.
- The product is scheduled for retail release on November 7, 2026, with a starting price of 299 yuan.
The Design Incorporates Premium Materials
Constructed from a high-quality aluminum alloy, the Wind Chaser prioritizes portability and aesthetic minimalism. When folded, the device maintains a slim profile that resembles a single solid piece, weighing only 27 grams. This compact design allows users to carry it easily while ensuring their smartphones remain stable in either landscape or portrait orientations.
The integration of a hidden hinge mechanism ensures that the physical footprint remains minimal during daily use, catering to power users who require reliable thermal management without the bulk of conventional cooling accessories.
The Piezoelectric Fan Replaces Mechanical Blades
The primary innovation of the Huawei Wind Chaser lies in its bladeless piezoelectric cooling system. Unlike standard fans that depend on mechanical movement, this system uses high-performance ceramics to create airflow via rapid, controlled vibrations. At only 0.65 mm in thickness, the fan operates at two distinct speed levels, achieving wind output speeds reported to be over 100 percent higher than traditional miniature mechanical fans. This development demonstrates how advanced material science can eliminate the need for space-consuming mechanical components while significantly improving thermal performance for smartphones.
The Suction System Ensures Compatibility
To address the challenge of mounting, Huawei implemented a unique adhesion technology modeled after the physical properties of a gecko. The underside of the stand features roughly 400,000 microscopic contact points that provide a secure, residue-free grip on nearly all smartphone surfaces and protective cases. This system supports up to 40 newtons of force, ensuring the device remains securely attached during intensive tasks such as gaming or high-resolution video recording. Because the system does not rely on magnets or chemical adhesives, it maintains its effectiveness even after repeated use and does not leave marks on the hardware.
The Market Availability Begins Shortly
The Huawei Wind Chaser is positioned as a sleek, professional-grade accessory for users seeking to manage device temperatures effectively. With its combination of a durable aluminum frame and cutting-edge piezoelectric cooling technology, the device bridges the gap between passive stands and active cooling systems. The product will be available through Huawei’s official online store, authorized retailers, and physical experience centers starting November 7, 2026, with a retail price of approximately 45 dollars.
We are eager to hear your thoughts on this new cooling technology; do you believe piezoelectric fans will become the standard for mobile cooling, or do you prefer traditional mechanical fans? Share your opinions in the comments section below.
