Computers
    OntheGo 7-in-1 USB-C hub keeps it light, compact, and magnetic
    Satechi’s OntheGo 7-in-1 USB-C hub offers seven ports, MagSafe-friendly magnetic mounting, and weighs just 68g for true portability.
    OntheGo-7-in-1-USB-C-hub-1
    Satechi’s new OntheGo 7-in-1 USB-C hub makes a strong case for staying mobile without sacrificing connectivity. Designed for users on the move, it squeezes seven essential ports into a palm-sized shell that weighs less than a deck of cards and sticks right to your device with magnets.
    OntheGo-7-in-1-USB-C-hub-2
    At just 6.5 cm wide and weighing 68 grams, the OntheGo hub is meant to disappear into a backpack or cling directly to your gear. Thanks to built-in magnets and a magnetic ring accessory, it can snap onto iPhones with MagSafe or attach to a laptop lid without getting in the way.
    Its round shape isn’t just for looks. The ports line the outer edge, giving the hub a balanced feel that avoids cable chaos. A 13 cm USB-C cable tucks neatly into the base, keeping the setup clean and ready for quick deployment.
    GTA VI Switch 2 port reportedly in the works after strong launch
    Despite the small footprint, the OntheGo hub comes loaded with the right mix of ports. Satechi’s layout favors flexibility, whether you’re working on a MacBook, Chromebook, or iPad.
    Here’s what it packs in:
    • 1 x HDMI (4K @ 60Hz)
    • 1 x Gigabit Ethernet port
    • 2 x USB-A (5 Gbps)
    • 1 x SD card reader (up to 2 TB)
    • 1 x microSD card slot (up to 2 TB)
    • 1 x USB-C Power Delivery (100W input / 80W output)
    That’s enough to handle media transfers, wired networking, display output, and high-speed charging all from one hub that fits in your hand.
    Plenty of USB-C hubs claim to be portable. The OntheGo actually delivers. With its magnetic mount and tidy cable wrap, it works as a sleek companion for mobile creators, students, or anyone who lives off their laptop.
    Even better, it plays nicely with nearly any platform MacOS, iPadOS, ChromeOS, Windows, or iOS. Just plug in and go. Or stick it on and forget it’s even there.
