OPPO Develops New Wide-Body Smartphone With 8,000 mAh Battery
OPPO is currently developing a unique, non-foldable wide-body smartphone that promises to redefine standard device form factors. Industry reports suggest that this innovative handset, potentially branded as the Reno X, is scheduled for an official market debut in the first quarter of 2027. By opting for a wide-body design rather than a traditional folding mechanism, the manufacturer aims to provide an expansive display experience that prioritizes structural integrity and screen real estate. The upcoming device is expected to pack a massive 8,000 mAh battery, significantly exceeding current industry standards for daily power consumption and long-term usage sustainability.
- The device will feature an exceptionally large 8,000 mAh battery capacity for extended power performance.
- Dual 200-megapixel sensors will likely serve as the primary camera configuration for high-resolution photography.
- The handset is expected to utilize the MediaTek Dimensity 9600M chipset for improved processing speeds.
- Market release is currently projected to occur during the first quarter of 2027.
High-End Hardware Specifications Are Being Integrated
The technical architecture of this new model indicates a strong focus on raw performance and visual clarity. Under the hood, the device is rumored to house the MediaTek Dimensity 9600M processor, a chipset designed to handle demanding applications and multitasking with ease. This hardware choice reflects the company’s commitment to ensuring that the expansive screen size is matched by equally capable internal processing power.
Visuals are handled by a 6.35-inch display that adopts a traditional 16:9 aspect ratio, moving away from the elongated screens seen in many modern flagships. The panel is expected to support a 120 Hz refresh rate, ensuring smooth scrolling and fluid motion, while the 2560 × 1440 pixel resolution promises a sharp, high-definition viewing experience. By choosing this specific display configuration, the manufacturer addresses the demand for a wider workspace without the complexities inherent in foldable hardware.
Advanced Camera Systems Are Being Developed
Photography enthusiasts may find the rumored camera setup particularly compelling. Reports suggest that the back of the device will feature two separate 200-megapixel sensors, a configuration that could drastically improve image detail and low-light performance. This high-resolution approach allows for professional-grade cropping and detail retention, which is essential for a high-end mobile device aimed at content creators and photography hobbyists.
Design Philosophy Is Focusing on Reliability
The decision to avoid a foldable screen suggests that the company is aiming for a more durable and reliable alternative for users who require a larger display. The internal designation of Reno X could imply a focus on premium aesthetics combined with the practicality of a non-mechanical design. By skipping the folding hinge, the company potentially avoids the common longevity issues associated with flexible displays, providing a stable, wide-body platform for productivity and multimedia consumption.
We are eager to hear your thoughts on this bold move by OPPO. Do you believe there is a market for wide-body, non-foldable smartphones, or do you prefer the portability of traditional designs? Share your opinions in the comments section below.
