Oppo Launches F35 and F35 Pro Featuring 8,000 mAh Batteries
Oppo has officially unveiled its latest smartphone lineup, the Oppo F35 series, during a recent global launch event. The new series consists of the base Oppo F35 and the premium Oppo F35 Pro, both of which distinguish themselves in the competitive mobile market by integrating massive 8,000 mAh capacity batteries. Designed to cater to modern users who prioritize extended uptime and high performance, these devices promise to eliminate common battery anxiety. By combining advanced hardware specifications with substantial power reserves, Oppo aims to set a new standard for longevity in the midrange and flagship-killer segments.
- The Oppo F35 and F35 Pro both feature industry-leading 8,000 mAh battery capacities.
- The Pro model utilizes a MediaTek Dimensity 7360 MAX processor, while the base model runs on the Dimensity 6360 MAX.
- Both smartphones provide versatile charging options, including 80W SuperVOOC support and IP69 water and dust resistance.
Detailed Specifications of the Oppo F35 Pro Are Highlighted. The Pro variant boasts a sophisticated 6.78-inch OLED display that supports a 144 Hz refresh rate and a resolution of 1,272 x 2,772 pixels. This panel achieves 1,800 nits of peak brightness in HBM mode and covers the entire DCI-P3 color gamut. Powering this device is the MediaTek Dimensity 7360 MAX chipset, built on a 4nm architecture that balances efficiency with high-speed performance.
The internal configuration offers users a choice between 6 GB or 8 GB of LPDDR5X RAM, paired with either 128 GB or 256 GB of UFS 3.1 internal storage. Photography enthusiasts will appreciate the 50 MP main sensor equipped with OIS, complemented by an 8 MP ultra-wide lens. Notably, the front-facing 50 MP camera supports 4K video recording at 30 FPS, ensuring high-quality content creation for social media users.
Standard Oppo F35 Specifications Are Defined.
The standard Oppo F35 model is equipped with a 6.57-inch OLED screen, offering a 120 Hz refresh rate and 1,400 nits of peak brightness. Under the hood, it utilizes the MediaTek Dimensity 6360 MAX processor, which is paired with 6 GB or 8 GB of LPDDR4X RAM. Storage options for the base model include 128 GB of UFS 2.2 capacity.
Despite its position as the entry-level device, the F35 retains a robust 50 MP primary sensor and a 2 MP depth sensor. The front camera matches the Pro model with a 50 MP sensor, featuring a 100-degree field of view and autofocus. Both models share the same charging standards, including 80W SuperVOOC, 55W USB PPS, and 44W UFCS.
Market Availability and Pricing Are Announced.
Durability remains a core feature of this series, as both devices are certified with an IP69 rating, ensuring high resistance against environmental hazards. The Oppo F35 series is available in several colors, including Wave Blue, Mist Pink, and Titanium Grey for the standard model, while the Pro version arrives in Sunrise Orange, Wave Blue, and Twilight Brown.
Pricing for the base F35 starts at $400 for the 6 GB/128 GB configuration, reaching $450 for the 8 GB/128 GB version. The F35 Pro carries a premium, starting at $480 for the base model, while the top-tier 8 GB/256 GB variant is priced at $570. These price points position the series competitively against other flagship contenders currently available on the market.
With smartphone battery life often cited as the biggest frustration for daily users, the introduction of an 8,000 mAh capacity is a significant shift in design philosophy. Do you believe that sacrificing a slimmer form factor for such a massive battery is a trade-off you are willing to make, or do you prefer thinner devices with standard charging habits? Let us know your thoughts in the comments section below.
