    Sony Cinema Line FX5 Announced With Full Frame Power
    Sony announces the new Cinema Line FX5, a compact full-frame camera featuring 16-bit internal RAW recording, AI-powered autofocus, and 3:2 Open Gate shooting.
    Sony has officially expanded its prestigious Cinema Line series with the launch of the FX5, a professional full-frame camera designed to redefine video production capabilities. Announced globally to cater to both independent filmmakers and large-scale production crews, the Sony Cinema Line FX5 integrates a newly developed stacked Exmor RS CMOS sensor paired with the BIONZ XR2 image processing engine. This compact and highly portable device delivers cinematic quality through features such as 15+ stops of dynamic range, internal 16-bit X-OCN RAW recording, and the highly anticipated Open Gate shooting mode. By combining high-end performance with a robust ergonomic design, Sony aims to provide a versatile tool that handles demanding field conditions with ease.
    • The camera features a full-frame stacked sensor capable of internal 16-bit X-OCN RAW recording without requiring external hardware.
    • It supports 3:2 Open Gate shooting for the first time in the FX series to provide maximum flexibility for post-production framing.
    • The device incorporates an artificial intelligence processing unit that performs human pose estimation for precise subject tracking.
    • An upgraded 5-axis in-body image stabilization system works in tandem with an active cooling fan to ensure professional reliability.
    Sensor Technology Sets New Standards
    At the heart of the Sony Cinema Line FX5 lies a sophisticated stacked CMOS sensor that significantly enhances readout speeds and image fidelity. The camera offers impressive high-speed shooting capabilities, supporting 5K resolution at 60 fps, 4K at 120 fps, and Full HD at 240 fps. This level of technical performance ensures that motion is captured with exceptional clarity and smoothness.
    The inclusion of Open Gate mode marks a significant milestone for the Cinema Line series, as it utilizes the full 3:2 area of the sensor. This functionality provides editors with extensive cropping options, allowing for easier adaptation to both vertical and horizontal aspect ratios during the post-production stage. Additionally, the system supports various anamorphic lens de-squeeze ratios, further expanding creative possibilities.
    The camera eliminates the need for bulky external recorders by enabling direct internal RAW recording onto standard memory cards.
    AI Tracking Enhances Subject Focus
    Sony has equipped the FX5 with a dedicated AI processing unit that utilizes advanced human pose estimation technology. This system tracks not only the eyes but also the head and body movements of subjects, maintaining focus even in challenging lighting environments. Furthermore, the Auto Tracking White Balance feature leverages infrared sensors and deep learning algorithms to ensure accurate color temperature during shifting light conditions.
    Audio Architecture Reaches New Heights
    The accompanying XLR-H2 handle introduces a revolution in audio quality with its 32-bit float recording support. This feature allows filmmakers to recover audio data that would otherwise be lost due to clipping or extremely low input levels, ensuring professional sound in every frame. The system also supports 96 kHz high-resolution audio across four channels via its combo inputs.
    Durability Defines Professional Performance
    Designed for real-world versatility, the FX5 features a flat-top body that allows for the direct attachment of accessories without the necessity of a camera cage. Its integrated 5-axis optical stabilization includes an enhanced roll correction mechanism to stabilize handheld or gimbal-mounted footage. To prevent overheating during extended RAW recording sessions, the camera utilizes an independent airflow cooling system that is resistant to dust and moisture.
    Sony has integrated 30 percent recycled plastic into the construction of the FX5 to promote environmental sustainability.
    We are curious to hear your thoughts on these new technical specifications; do you believe the internal 16-bit RAW recording feature will change your current production workflow? Please leave a comment below to share your perspective with our community.
