    vivo S2 FE Launches With Massive 10,000 mAh Battery
    Vivo has launched the vivo S2 FE, featuring a massive 10,000 mAh battery, 120Hz AMOLED screen, and MIL-STD-810H durability. Discover the full specs and pricing.
    Vivo has officially expanded its smartphone lineup with the introduction of the vivo S2 FE, a device that distinguishes itself through an unprecedented 10,000 mAh battery capacity. Building on the foundation of the original vivo S2 model launched in August, this new iteration aims to address the needs of power users who prioritize longevity over all else. The device, which is set to hit the market on October 20, combines this massive power cell with competitive mid-range specifications, including a 120Hz AMOLED display and the MediaTek Dimensity 7300e chipset, positioning itself as a unique contender in the current mobile landscape.
    • The device features a massive 10,000 mAh battery supported by 44W fast charging.
    • The handset is equipped with an IP69 rating and MIL-STD-810H certification for durability.
    • Pricing starts at 38,999 INR for the base 6GB/128GB storage configuration.
    Power and Visual Performance are Enhanced
    The standout feature of the vivo S2 FE is undeniably its 10,000 mAh battery, which ranks among the largest capacities ever integrated into a standard smartphone. To ensure this energy is utilized effectively, the manufacturer included 44W fast charging and reverse charging capabilities, effectively allowing the phone to function as a portable power bank. Complementing this energy capacity is a 6.83-inch AMOLED display that supports a 120Hz refresh rate, ensuring fluid interaction and high-quality visual output for media consumption. Security is managed through an under-display fingerprint sensor, maintaining a sleek aesthetic while providing quick access.
    Hardware and Camera Systems are Optimized
    Under the hood, the vivo S2 FE is powered by the MediaTek Dimensity 7300e processor. This chipset is engineered to balance power efficiency with the performance demands of daily multi-tasking and moderate gaming. The rear camera array consists of a 50 MP Sony IMX852 primary sensor paired with a 2 MP secondary lens for depth and detail. For front-facing photography, the device utilizes a 32 MP camera, which is designed to provide clear images and reliable video conferencing capabilities. The software experience is driven by OriginOS 6, which is built upon the Android 16 platform.
    Durability Standards are Strictly Maintained
    Constructed for environments that demand resilience, the vivo S2 FE carries an IP69 rating, offering high-level protection against dust and water ingress. Furthermore, the device meets MIL-STD-810H military standards, ensuring that it can withstand physical shocks and extreme conditions. Connectivity is fully realized with support for 5G, Wi-Fi 6, and Bluetooth 5.4, covering all essential modern networking requirements.
    Market Availability is Confirmed
    The vivo S2 FE will be available for purchase starting October 20 in three color variants: Stellar Green, Titan Black, and Zen White. The 6GB/128GB model carries a price tag of 38,999 INR, while the 8GB/128GB version is priced at 42,999 INR, providing options for different storage needs.
    Given the current trends in smartphone battery technology, we are curious to hear your thoughts on this release. Would a 10,000 mAh battery significantly change your daily mobile experience, or do you prefer a lighter device? Share your opinions in the comments section below.
