Xiaomi Launches Ultra-Thin 10000mAh Magnetic Power Bank
Xiaomi has officially expanded its portable charging lineup with the release of the new Xiaomi 10000mAh 45W magnetic power bank, now available via the Xiaomi Youpin platform for 399 yuan. This device represents a significant technological leap in the portable power category, utilizing advanced silicon-carbon battery chemistry to achieve a remarkably compact and lightweight form factor. Designed for modern users who demand both speed and portability, the power bank delivers versatile charging options through both wired and wireless interfaces, effectively serving as a high-performance successor to the brand’s previous WPB1025S model while maintaining full compliance with rigorous safety standards.
- The device utilizes high-density silicon-carbon battery cells to achieve a 35% reduction in size compared to its predecessor.
- The integrated USB-C port supports up to 45W wired output and 30W input for rapid recharging cycles.
- Advanced thermal management systems, including NTC temperature control and graphene cooling, ensure operational safety during high-power usage.
- The compact 195-gram design meets international aviation safety standards for worry-free travel.
Design Specifications and Build Quality Are Enhanced
The Xiaomi magnetic power bank features a premium aluminum alloy casing, measuring only 102 x 70.5 x 13.2mm. By incorporating a sophisticated silicon-carbon anode structure with 840Wh/L energy density, the engineers successfully reduced the unit’s weight to just 195 grams. This iteration is 43 grams lighter and 6.6mm thinner than the previous 33W model, making it an ideal companion for daily commuters and travelers alike.
Users can access granular performance data by connecting the device to a computer via the USB-C port. This interface allows for real-time monitoring of battery health, current voltage levels, and thermal metrics, providing transparency into the device’s longevity and efficiency.
Charging Capabilities and Performance Standards Are Defined
Equipped with a versatile USB-C port, the power bank provides a maximum wired output of 45W and supports a wide array of industry protocols, including USB PD 3.0, PPS, and Quick Charge 3.0. For wireless charging enthusiasts, the magnetic pad delivers up to 20W of power to compatible Xiaomi flagship handsets.
While Apple device users can expect a standard 7.5W wireless output, the power bank maintains its utility by allowing simultaneous wired and wireless charging. When both methods are utilized, the total output is capped at 15W to protect the internal circuitry. Safety remains a priority, with the inclusion of a graphene heat dissipation layer and thermal silicone to prevent overheating during intensive charging sessions. The unit fully adheres to the GB 47372-2026 portable battery safety standards and falls under the 100Wh capacity limit, ensuring it remains permissible for carry-on luggage on commercial aircraft.
Given the shift toward ultra-thin and high-capacity portable hardware, does this new design address your daily charging needs, or do you prefer larger capacities regardless of the bulk? Share your thoughts in the comments section below.
