Baseus 100W power bank brings big charge and built-in cables
Baseus has pulled the curtain back on its latest portable charger, and it’s packing serious firepower. The new EnerFill FC41 power bank comes with a hefty 20,000mAh capacity, support for 100W fast charging, and a clever cable setup that aims to make travel charging simpler.
Baseus 100W power bank handles laptops and more
This isn’t just for topping off your phone. The EnerFill FC41 is rated to handle everything from earbuds to laptops, thanks to broad protocol support. SCP, AFC, FCP, QC, PD, PPS, and UFCS are all covered. That flexibility means it’s likely compatible with nearly every modern device you’ll toss its way.
In terms of speed, the numbers are sharp. Baseus claims the power bank can boost a 13-inch MacBook Air to 36% in just 30 minutes using 100W fast charging. That’s a big deal for travelers and hybrid workers who don’t always have time for a full charge.
Xiaomi Portable Photo Printer Pro goes global with compact, colorful prints
Dual built-in cables make the Baseus 100W power bank travel-ready
Built-in cables are often hit or miss, but Baseus has taken a practical approach. The FC41 comes with two integrated USB-C cables that sit snugly into a buckle system, preventing annoying tangles. That’s a win for anyone tired of rummaging through a tangled mess in their bag.
But Baseus didn’t stop there. With two extra ports in addition to the built-in cables, this charger can juice up four devices at once. Here’s what that setup looks like:
- 2 × built-in USB-C cables
- 2 × additional charging ports
- 65W self-charging input
- Digital display for battery info
That’s a lot of utility in something that Baseus says is over 24% smaller than typical 20,000mAh power banks.
Baseus 100W power bank design stays compact and lightweight
Despite its capacity, the EnerFill FC41 doesn’t feel bulky. It’s designed to be held comfortably in one hand, and the trimmed-down footprint makes it easy to toss into a carry-on or backpack. The built-in digital display adds clarity, showing remaining battery and charging speed at a glance.
An AI-powered temperature control chip is also inside, helping manage heat during heavy output or self-charging sessions.
Global release of the Baseus 100W power bank is still pending
For now, the power bank is exclusive to China, launching at CNY 199 (about $28). That’s a solid deal for what it offers. Baseus hasn’t confirmed a global release date yet, but given the appeal, it likely won’t stay region-locked for long.
Baseus 100W power bank brings smart design to full-throttle charging
Between the size, power, and built-in convenience, the EnerFill FC41 isn’t chasing gimmicks. It’s all function, no fluff—and that’s exactly what makes it worth watching.
