RedMagic 12 Pro+ Debuts With 185Hz Screen and Liquid Cooling
The RedMagic 12 Pro+ has officially launched in China, setting a new industry benchmark as the first smartphone to feature a 185Hz display refresh rate. Unveiled during a major product event, this flagship gaming device introduces an advanced RGB liquid cooling system and cutting-edge hardware configurations. Powered by the Snapdragon 8 Elite Extreme Gen 6 chipset and the proprietary RedCore R5 gaming processor, the phone is designed for elite performance. With options including 16GB of LPDDR5T RAM and 1TB of UFS 4.1 Pro storage, the RedMagic 12 Pro+ establishes itself as a powerful contender in the competitive mobile gaming market.
- The device features the industry-first 185Hz AMOLED display with a peak brightness of 5,000 nits.
- An integrated RGB liquid cooling system manages heat using a high-speed, IPX8-certified fan.
- The handset packs a massive 8,400 mAh battery supporting 120W wired and 80W wireless charging speeds.
- Global availability details for the device are scheduled for announcement on November 3.
Display Technology Provides Exceptional Visuals
The device sports a 6.85-inch AMOLED panel that balances resolution and speed perfectly. With a resolution of 1216×2688 pixels, the screen achieves a peak brightness of 5,000 nits, ensuring visibility even in direct sunlight. Protected by Gorilla Glass 7i, the display boasts a 96.3% screen-to-body ratio, achieved through extremely thin 0.96mm bezels.
Additionally, the phone integrates a ninth-generation 16MP under-display selfie camera developed in collaboration with BOE, ensuring an unobstructed viewing experience for gamers.
Cooling Systems Maintain Peak Performance
Thermal management serves as a cornerstone of the device’s design. The RedMagic 12 Pro+ utilizes a sophisticated dual-loop liquid cooling system paired with an RGB-lit rear module that reacts to in-game actions. The internal micro-pump delivers an 85% performance increase over the previous generation.
Supported by a 25,500 RPM fan and a five-layer thermal structure—incorporating graphene, vapor chambers, and liquid metal—the system effectively prevents thermal throttling during intense gaming sessions.
Battery Capacity Supports Long Gaming Sessions
To sustain its high-performance hardware, the manufacturer has equipped the device with an 8,400 mAh battery. Users benefit from 120W wired and 80W wireless charging, complemented by bypass charging features that preserve battery health. For connectivity, the device includes Wi-Fi 7, Bluetooth 6.0, and an IR blaster. The inclusion of a 3.5mm headphone jack and 700Hz capacitive shoulder triggers further caters to the needs of professional mobile gamers.
Camera Capabilities Offer High-End Versatility
Despite its gaming focus, the device features a capable camera system, including a 50MP primary sensor with OIS and a 50MP ultra-wide lens. It is capable of recording 8K video, housed within a chassis that is only 8.55mm thick and weighs 223 grams. The phone meets IP68 and IP69 standards for water and dust resistance, ensuring durability in various environments. Running on RedMagic OS 12 based on Android 17, the phone also provides advanced emulation features for Steam users, though compatibility varies by title.
The RedMagic 12 Pro+ pushes mobile gaming boundaries with its 185Hz display and massive cooling capabilities, but we would love to hear your thoughts. Do you think a 185Hz refresh rate makes a noticeable difference in your mobile gaming experience, or does the hardware focused on cooling impress you more? Share your opinions in the comments section below!
