Redmi 17 4G Technical Specifications Surface With 7500mAh Battery
The upcoming Redmi 17 4G has surfaced in extensive leaks, confirming its hardware configuration ahead of the official market release. Previously spotted in EPREL databases, this budget-friendly device is poised to challenge the entry-level segment with a massive battery capacity and a robust display panel. While earlier industry rumors suggested the integration of a Snapdragon processor, recent documentation confirms that the device will be powered by the MediaTek Helio G91-Ultra chipset, built on a 12nm manufacturing process. This confirmation provides clarity for consumers tracking the Redmi 17 4G launch, which promises significant performance upgrades for a device in this price bracket.
- The Redmi 17 4G features a massive 7,500mAh battery paired with 45W fast charging technology.
- The device incorporates a 6.9-inch display with a 120Hz adaptive refresh rate and 825 nits peak brightness.
- Internal hardware includes the MediaTek Helio G91-Ultra chipset with multiple RAM and storage configurations.
- Durability is enhanced through an IP64 rating and Corning Gorilla Glass 7i protection.
Display Technologies Offer High Performance
Designed for users prioritizing screen real estate, the Redmi 17 4G sports a 6.9-inch flat display with a resolution of 1600 x 720 pixels. The panel supports a 120Hz adaptive refresh rate, ensuring fluid navigation and visual fidelity. To enhance user comfort, the screen has received TÜV Rheinland certifications for low blue light emission and flicker-free performance.
The integration of Gorilla Glass 7i provides superior screen protection against accidental drops and scratches.
Design Elements Ensure Durability
The physical construction of the Redmi 17 4G measures 170.12 x 78.42 x 8.8 mm, resulting in a total weight of 232 grams. The manufacturer has prioritized build quality by including an IP64 rating, which offers reliable protection against dust and water splashes. Consumers can choose from several colorways, including Oak Green, Deep Blue, Black, and Lotus Purple, allowing for a personalized aesthetic. The chassis also features integrated Dynamic RGB lighting, adding a modern touch to the overall design.
Camera Systems Capture Clear Images
For photography needs, the device houses a 50MP primary sensor with an f/1.8 aperture on the rear. This setup is complemented by an 8MP selfie camera located on the front of the device.
The device supports 1080p video recording at 30 frames per second for both front and rear camera modules.
Battery Capacities Define Power Usage
The defining feature of the Redmi 17 4G is undoubtedly its substantial 7,500mAh battery. To ensure efficient recharging, the handset supports 45W fast charging, significantly reducing downtime for the user. Software-wise, the device ships with HyperOS 3, providing a streamlined user experience out of the box. Additional security is provided by a side-mounted fingerprint scanner and advanced facial recognition technology. Connectivity options include dual-band Wi-Fi and NFC support, which will vary depending on the specific regional requirements of the market.
What are your thoughts on the massive 7,500mAh battery included in the new Redmi 17 4G, and would this be the primary reason for you to consider purchasing this device?
