Vivo X300 Pro review: Stellar camera meets a few costly flaws
The Vivo X300 Pro has landed with high expectations and in most ways, it delivers. Positioned as a premium camera-first smartphone, this flagship flexes some serious hardware muscle. But dig a little deeper, and a few key drawbacks begin to surface.
Vivo X300 Pro camera setup leads the charge
At the center of the X300 Pro experience is its Zeiss-backed triple-camera system, which pulls no punches. Photos are sharp, colors stay natural, and the dynamic range holds strong even in tricky lighting. Night shots come out clean, and video capture impresses with solid 8K capability and dependable stabilization.
The front camera doesn’t fall behind either it supports autofocus and shoots in 4K, which isn’t always a given in this segment.
Oppo Find X9 Ultra specs leak with hints of global launch
Vivo X300 Pro display and build bring flagship polish
The 6.78-inch LTPO AMOLED screen is another strong point. It reaches high brightness levels, supports HDR, and adapts refresh rates between 1 and 120Hz. Color accuracy is tight, and the overall viewing experience is high-end.
As for the body, it’s a solid mix of glass and aluminum, IP69-certified for water and dust protection. Still, the top-heavy camera bump can throw off the balance slightly in hand.
Feature-rich, but not without skips
On the connectivity front, the X300 Pro covers a lot of ground:
- WiFi 7
- Tri-band GNSS
- Dual SIM + eSIM
- Ultrasonic fingerprint sensor
- 7 years of security updates, 5 years of Android upgrades
That said, some things are missing. There’s no UWB, no barometer, no headphone jack, and no microSD support. The phone also ships without a charger something that still feels off at this price point.
Thermal issues and weak audio hold it back
While the specs look great on paper, the Dimensity chipset throttles heavily under sustained use. GNSS performance is sluggish when acquiring satellite signals. And the stereo speakers? Crisp at low volume, but they start to sound harsh when pushed.
Battery life is acceptable, but not a standout, especially for a phone in this tier.
Vivo X300 Pro nails photos, but slips in balance
If you care about photo quality, the Vivo X300 Pro won’t disappoint. But those looking for across-the-board excellence might notice its cracks. Thermal throttling, mediocre speakers, and some missing features slightly undercut its premium pitch.
